Author Topic: 5 door conversion  (Read 1886 times)
Offline karlos_82
5 door conversion
« on: 10 May 2004, 20:53 »
Hi,
Has anyone ever converted a 5 door golf mk2 gti to a 3 door. Is it possible? Any input would be appreciated.
Offline Dizzie
  • Make friends with your fast
Re:5 door conversion
« Reply #1 on: 11 May 2004, 09:01 »
it is possible, and you'd be the first as normal people just buy a 3dr. :)
Mk4 Golf 150PD
Speedydub
« Reply #2 on: 11 May 2004, 13:06 »
I think you just weld the back doors up. Seen a sierra cossie lookalike like it and it looked sh!t  ::)
Offline AdamB
  • The Perfect Storm
« Reply #3 on: 12 May 2004, 07:47 »
Doing this would cause problems in rear access, as 2/3 door cars have longer doors to enable easier rear entry. Not a big problem unless you always carry rear passengers, in which case the safety aspect in a crash comes into play.
« Last Edit: 12 May 2004, 07:48 by AdamB »
I don't own this anymore - I just can't be arsed to change the picture
Offline dubslug
« Reply #4 on: 12 May 2004, 08:22 »
if u want that sort of look why dont u remove the handles fill in the recess?? that way rear doors can still be opened from inside??
or just get a three door to start with
1992 pearl grey 8v
