Author Topic: are they the same?  (Read 1798 times)
Offline 1300mk2
are they the same?
« on: 10 May 2004, 19:49 »
just wondering if the cam belt cover in a pre 85 (manual tappets) mk2 golf has the same cam belt cover as any mk 1s. the cover is the metal type and when located in place has two screws. one holding the dip stick guide and the other through the middle of the cover.
thanks in advance
Offline Dizzie
  • Make friends with your fast
Re:are they the same?
« Reply #1 on: 11 May 2004, 00:15 »
as far as I'm aware the cambelt cover is the same on all the mk1 8v's and all the mk2 8v's.
I have no idea what you're on about with the dip stick though. the cambelt cover is held on by 2 (or the 8) 10mm nuts that hold the rocker cover on and a 6mm allen bolt on the side.
Offline mk1
« Reply #2 on: 11 May 2004, 19:31 »
The dip stick thing is 'coz his is a 1300 Diz ;).
I think mk1 1300 should be the same.
Steve.
