Author Topic: alloys  (Read 1750 times)
Offline andy mac
alloys
« on: 10 May 2004, 19:20 »
can anyone tell me if a set of alloys bought for a renault laguna will fit my mk11 8v,they are definately 4 x 100 pcd,but is there more i need to know,any help would be appreciated.
Offline davidhawkins_78
  • Valver Bad Boy
Re:alloys
« Reply #1 on: 11 May 2004, 15:41 »
The PCD is correct, so the studs will line up - but the centre bore will be different so the wheel will not be 'hub centric', so it won't spin properly.
Get some custom spigot rings and you'll be fine - I had the same problem and there's someone specific you can get them from but I can't fecking remember their name ... anyone help out here ?
You'll need something to convert the wheels to a 57mm centre bore from whatever your wheels are currently.
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
  • Valver Bad Boy
Re:alloys
« Reply #2 on: 11 May 2004, 15:45 »
Just found them !!!
R-Tec in Hatfield will be able to sort you out ....
The phone number is 01727 790100
Offline andy mac
Re:alloys
« Reply #3 on: 11 May 2004, 21:26 »
do the custom spigot rings have a wheel flange with them ,ie do the wheel bolts go through them or are they just for the centre hub boss,i
am asking because if they are just for the centre boss i will mic up dimensions and make some myself on a lathe,thanks for the info
Offline andy mac
Re:alloys
« Reply #4 on: 04 June 2004, 21:53 »
got them on bk604 17s ,ended up buying some wheel hub spacers at ?20. a bit steep for four bits of plastic but they look spot on,totally transformed the look of the car
