Author Topic: Changing the brake light switch  (Read 969 times)
Offline andydavey
« on: 05 September 2008, 09:44 »
How easy is this to do on a MK2? Is there a guide anywhere?
Have done a search but didn't really find anything, true to form the Haynes manual doesn't say anything about it either. I've got an intermittent problem with my brake lights not working and I think the switch is probably the culprit, unless anyone else has any ideas?
Re: Changing the brake light switch
« Reply #1 on: 05 September 2008, 09:52 »
1st step, get under there and grab the end of the switch, give it a firm tub to extend it. then press the pedal and it will self adjust.  if that doesnt fix it you simply twist the switch to release it from the bracket :)
