Author Topic: MK3 DASH IN MK2 GOLF  (Read 9821 times)
Offline ooh_ooh_gti_crew
« on: 10 May 2004, 18:39 »
HAS ANYBODY DONE THIS AND IF SO CAN YOU LET ME KNOW HOW HARD IT IS AND WHAT SORT OF THINGS I HAVE TO BEAR IN MIND.
CHEERS,
JAMES.
Offline RandomJord
Re:MK3 DASH IN MK2 GOLF
« Reply #1 on: 10 May 2004, 19:02 »
Umm i havent myself but i think Dizzies done a dash swap, ask him
Skoda Octavia VRS DSG (soon!)
Skoda Rapid Spaceback
An a Signum for towing me old caravan!
Blue MK2
« Reply #2 on: 10 May 2004, 20:28 »
thers a dash going cheap.
ill PM you with the link
Offline vixteris
« Reply #3 on: 10 May 2004, 20:34 »
dizzie is gonna love this thread  ;) :D
« Reply #4 on: 10 May 2004, 21:18 »
Cheers Blue but I already have the dash and all switches, clocks etc.
I fit Intruder alarms for a living and the local breakers want one fitting so I am taking the dash as part payment.
I also need to know if I have to change the clocks or if I can keep the MK2 ones so as I can keep the milage accurate.
Cheers again,
James.
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 11 May 2004, 00:05 »
which year mk2? I'm heard the '90 spec ones you can just plug the mk3's clocks straight in and with a speed sensor in the gearbox the speedo comes to life. Take it to vw and they should be able to plug their kit in and change the mileage. so  I've heard.
Anything else you want to know about the swap just holla. ;D
btw, the mk3 stalks are a direct swap on a '90 spec mk2 too. if you're isn't '90 spec you'll need to get the ignition surround if you want to use the mk3 stalks.
« Reply #6 on: 11 May 2004, 00:16 »
Hi Dizzie
I have already done the stalks and I fear that this is as easy as it gets.
I just want to know how easy (or hard it is) to do the actual swap and what other parts I need to carry it out apart from the dash and switches.
I have read about changing the heater box, steering column and wiring loom.
Is this correct?
Thanks in advance,
James.
Blue MK2
« Reply #7 on: 11 May 2004, 14:59 »
here is a link for abit more info mate....
http://www.centralboardshop.com/projectvr6-5.html
did u get the link to that mk3 dash going cheap on ebay ??
« Reply #8 on: 11 May 2004, 18:50 »
Cheers blue
