Author Topic: Steering Problem  (Read 6229 times)
Offline jimmyob
Steering Problem
« on: 03 September 2008, 14:41 »
hi guys,
     a few more problems have popped up on my car.
     This is the latest, been doing a bit of motorway driving and there'a few problems with the steering:
           When the wheel's centered there's a lot of play before i feel any resistance.
           I'm getting quite a lot of vibration at speed as if the wheels are unbalanced (they were balanced only a month ago)
           This seems to get worse when turning left on the motorway.
           The car is pulling to the left (defo pulling as tracking is fine at low speeds)
           When i feed the steering wheel back after turning it returns in notchy stages.
           There's funny wobble to the car as if one front wheel is oval shaped. (As far as i know all the wheel are round though lol)
I have a feeling that a lot of these aren't related but was thinking some of them could be something to do with a wheel bearing?
Any help would be great so i dont have to spend 94 grand 50 on a diagnosis,
Jim
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Steering Problem
« Reply #1 on: 03 September 2008, 17:36 »
Track/tie rod end(s)??
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Rhyso
« Reply #2 on: 03 September 2008, 19:55 »
power steering fluid all present and correct? Rich has had to replace his steering rack  :sad:
Offline jimmyob
« Reply #3 on: 03 September 2008, 20:38 »
where's the level for that? i'll have a look tomorrow
Offline Rhyso
« Reply #4 on: 03 September 2008, 20:41 »
top left corner i believe iif you stand in front of the car
Offline richw911
« Reply #5 on: 03 September 2008, 21:10 »
As said check these first ^^^^^
 Sounds like something loose IMO, Have you had any new steering parts fitted?
 :undecided:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #6 on: 03 September 2008, 21:17 »
rhyso is right classic signs of low fluid, if it's a 1.8 turbo then your pump may have failed, up my mates garage last week and he was doing a pump on one and said it's his 3rd one this year so seems a common fault.
Offline richw911
« Reply #7 on: 03 September 2008, 21:19 »
And as rhys says Steering racks go for a pass time, mine was firing fluid out from the rubber boot  :shocked:
Offline Rhyso
« Reply #8 on: 03 September 2008, 21:21 »
cor - right twice in the same thread!!  :shocked:
i'm off for a lie down to get over the shock!!  :laugh: :laugh:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #9 on: 03 September 2008, 21:22 »
mmmmm got to wonder about the golfs reliabilty sometimes :undecided:
