Author Topic: Clutch......OR Gearbox?????  (Read 2216 times)
Offline Matt_Mk4
« on: 03 September 2008, 08:37 »
Hello all,
Not sure what is wrong, so thought I would ask you guys!
Basically, when the car is running and in Neutral, and my foot is off the clutch, there is a horrible rattling/knocking noise from the gearbox area
As soon as I put my foot on the clutch, the noise dissapears. Sometimes, when I release the clutch pedal again the noise doesn't come back, but sometimes it does!
Any ideas?
Offline ben1.8T
Re: Clutch......OR Gearbox?????
« Reply #1 on: 03 September 2008, 08:55 »
Could be the release bearing on the clutch.
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline Rhyso
« Reply #2 on: 03 September 2008, 10:53 »
or flywheel
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #3 on: 03 September 2008, 13:11 »
Either of the above.
Just out of interest, how many miles has your motor done & which model is it?
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Matt_Mk4
« Reply #4 on: 03 September 2008, 13:37 »
97k miles
1999, 1.8T, AGU engine
« Reply #5 on: 03 September 2008, 13:56 »
In that case, I'd recommend getting the lot done whilst it's all apart - Clutch/Fly/Bearing.  The clutch usually takes the flywheel out (or could be the other way around or both - I can't remember).  No point paying for more than 1 lot of labour! :wink:
Unless you're good on the spanners yourself??
Offline Matt_Mk4
« Reply #6 on: 03 September 2008, 13:57 »
Useless with spanners mate if I'm honest!
How much you reckon I would be looking at for the lot - fitted?
*prepares himself for a big bill!*
« Reply #7 on: 03 September 2008, 14:17 »
Rich W has recently had his done - Think he paid about £400 (or just under), IIRC.
Offline dai-cymru
  • 1989 MK2 16V
« Reply #8 on: 03 September 2008, 17:09 »
will 99% be clutch release bearing especially if noise goes when clutch is pressed, how loud is it, had a celica with bearing gone done 10k in it and sold it like it never became a problem apart from noise it made which wasnt too bad on mine
Offline richw911
« Reply #9 on: 03 September 2008, 20:38 »
Indeed about £400 - can be cheaper tho this should help.....
http://www.golfgtiforum.co.uk/index.php?topic=87775.0  :smiley:
