Author Topic: Some info on inlet mani removal  (Read 1309 times)
Offline azzrobz
  • Mk3 GTi 16v Anni
« on: 02 September 2008, 23:56 »
Hey guys, im gonna attempt to polish up my inlet manifold on my abf tommorow if the weather holds up, an polish my Throttle body at the same time, is there anything i need to worry about takin the manifold and throttle body off??
Thanks in advance
Aaron  :smiley:
Offline azzrobz
  • Mk3 GTi 16v Anni
Re: Some info on inlet mani removal
« Reply #1 on: 03 September 2008, 13:23 »
no one  :sad:
kells
« Reply #2 on: 03 September 2008, 17:17 »
i dont have a abf but you will most certainly need to order new gaskets before you put it all back together or it will leak...my mate had a mare with his
Offline azzrobz
  • Mk3 GTi 16v Anni
« Reply #3 on: 03 September 2008, 23:22 »
Cheers bud, will do :smiley:
Offline pro-biotic
« Reply #4 on: 04 September 2008, 15:17 »
6mm allen key if its like a KR..
id worry about getting debris into the throttle body.
the polishing job will take forever - what equipment are you using
Offline Vdubbster
« Reply #5 on: 04 September 2008, 21:32 »
5 & 6mm Allen Keys
It took me absolutely ages to do mine! And I regretted starting it  :drool:
Offline azzrobz
  • Mk3 GTi 16v Anni
« Reply #6 on: 04 September 2008, 23:20 »
Ha ha a Black and decker drill lmao  :grin:, not as easy as i thought then, it'll probz take me more than a day then. will leave it for the time being and start on it later on, once ive got the rest of the car in shape. cheers for the info guys.  :smiley:
Offline Vdubbster
« Reply #7 on: 05 September 2008, 13:16 »
Heres mine, I started it while on the car, then removed it so i coould get inbetween all gaps. Once it was 600 grit all over I just polished it.
I have several small areas which show some small scratches, just cant be bothered to re sand & re polish.
My thumbs were killing me
Offline azzrobz
  • Mk3 GTi 16v Anni
« Reply #8 on: 05 September 2008, 15:26 »
Chwor that looks the nuts!!! deffo gonna be done, :evil: i think i'll start it on the car and take it off to give it the finishin touches, so are you gonna paint inside the letters???  How did you manage to keep debri from fallin into the manifold, or can you just rinse it out with water and leave to dry before putting it back on??
Offline Vdubbster
« Reply #9 on: 05 September 2008, 18:11 »
When you start it while its still attached you need to used a bed sheet or something to catch all the shavings!
And once its off, just bang a towel in each hole
I dunno, I think il paint the DOCH in Black, but not sure yet. Need to sort my rocker cover too
