Author Topic: mk3 8v Clutch / Gearbox Problems  (Read 1298 times)
Offline BeNiNuK
« on: 02 September 2008, 22:31 »
Ok, yet another problem.
Its a golf mk3 2ltr 8v
i was driving along and the clutch was slipping slightly, then all of a sudden the gear stick went loose and was able to move all the way to the left and right!  , but the clutch has to be in, the car seems to be stuck in a gear, but will come out when u press the clutch in, but u cant change the gear.
I have had a recon gearbox put in about 7 months ago, so this shouldnt have gone.
Offline irmscher
  • Mobile Engine Tuning www.premiertuning.com
Re: mk3 8v Clutch / Gearbox Problems
« Reply #1 on: 02 September 2008, 22:50 »
Sounds like the linkage has come loose from the gearbox somehow, not an expensive job.  can you get under the car to inspect the linkage?
Mobile Engine Chiptuning & Remapping Specialists
Cars tuned from £199 at base
info@premiertuning.com or Facebook
Offline BeNiNuK
« Reply #2 on: 02 September 2008, 23:12 »
cant really get under there but thats what i have been told about the linkage, any recomendations where u can get this done cheap around the leeds area? or isit DIYable? and prices on the parts?
Offline lee_lee08
  • 1996 GTI 8v
« Reply #3 on: 04 September 2008, 00:00 »
£7 from stealers!
left right gear linkage rod! (your one mite even pop back on its ball joint! mine did)
If the gears are stiff and your having to force them change the gearbox oil!
