Author Topic: pictures of dizzy, dizzy oh dizzy  (Read 2153 times)
Offline raks.2008
  • 1992 MK2 16V
Re: pictures of dizzy, dizzy oh dizzy
« Reply #10 on: 03 September 2008, 14:24 »
Thanks mate, but its not at 1000rpm, its 1050rpm.. Will still have a read...
« Reply #11 on: 03 September 2008, 14:26 »
yeah but +50 rpm isn't enough to worry about is my point ;)
Offline casinoblue
  • praise the lord for drunken impulse buying
« Reply #12 on: 03 September 2008, 20:03 »
hey guys,
where exactly is the mark on the dizzy to line up the rotor arm with? have had the dizzy off again and can't see an etched line anywhere :angry:
the only mark i can find is a small notch on the outside of the fixing bolt hole nearest the hall sender socket. does this line up with something on the head? there is no way the rotor arm will ever line up with this mark, rotor arm is around 10 o'clock when at TDC.
all the other timing marks are spot on, have checked through the flywheel viewing hole, cams are ok.
this is driving me nuts, have flattened the battery 3 times trying to get it going................. :sad:
thanks in advance,
james. :smiley:
« Reply #13 on: 03 September 2008, 20:05 »
its on the lip that the rotor arm sits on. if you clean up round the edge you should see it, also there is a notch cut out of the plastic dust cover behind the rotor arm :)
Offline casinoblue
« Reply #14 on: 03 September 2008, 20:19 »
thanks RJ,
can see a small notch in the mounting lip at about 11 o'clock to the dizzy cap keyway, is that the one you mean?
sorry for sounding dumb, my eyes ain't what they used to be :wink:
« Reply #15 on: 03 September 2008, 20:46 »
erm yeah thats probably it!
