Author Topic: Quick, mk3 thermostat, where is it?  (Read 932 times)
Offline gina2201
« on: 02 September 2008, 18:59 »
HI, does anyone have a pic or can tell me where the mk3 thermostat is 1.8 CL
cheers! asap or i am stuck where i am!
Offline bobbito
  • Hammer and Chisel Engineering
Re: Quick, mk3 thermostat, where is it?
« Reply #1 on: 02 September 2008, 19:26 »
Its behind the power steering pump. If you look at the front of the engine block its on the left near the bottom. Slacken power steering belt, remove pump. Did it on my mk3 gti took an hour of f-ing about as it the worst place to put a thermostat. Have fun.
Offline bored_Welsh_lad
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
