Author Topic: Help - Xenon washers not working  (Read 3385 times)
Offline Teutonic_Tamer
Re: Help - Xenon washers not working
« Reply #10 on: 02 September 2008, 19:40 »
I think the fuse for the headlamp washers is the same for all the other squirty bits - though no harm in checking both fuse boxes.  Make sure that if you are gonna pull each fuse to have a look-see, then remove the ignition key, and turn off the interior lights.
You can also check the pump relatively easy, but you need to remove the right fog light grille (one philips screw, and carefully pull), and the fog lamp also (3 Ph screws, and unclip the wiring).  The headlamp washer pump is on the front face of the resevior, and is the one nearest the outer edge - ie, looking through the fog lamp aperture towards the rear, the h/l washer is on the left.
HTH
I feel like a homo
Offline synnea
« Reply #11 on: 02 September 2008, 20:32 »
synea, just a daft question, but turn on your lights and try having a squert, and see if they work then. They only operate in the dark, lights are on, or breaking the speed limit if they are set on auto!.  :smiley:
just seen TT mention aswell  :rolleyes:
Yes did all that still not working. I think something needs replaced for sure. Thanks TT also for the help. Gonna see here if I can check the fuse.
R32 : DBP : Lux Pack : Winter Pack : Cruise : Leather : Parking Sensors : Rear Tints : Armrest : RNS 510 : Ipod MediaIn : FreeView Tuner : VagCom
