Author Topic: Help - Xenon washers not working  (Read 3384 times)
Offline synnea
« on: 02 September 2008, 18:32 »
Need some advice please, as most of you have probably read I got my GTI on Saturday. All has been well so far, however since using the windscreen washers a few times I have noticed my xenon washers do not 'pop up' and spray the lights. The R32 I used to have and GT TDI with winter pack also had the washers. They would activate on about every 5th use of the windscreen washers or every 5th time the lights are turned on.
I was driving last night with my lights on and sprayed on/off the windscreen washer about 10 to 15 times. Not once did the headlight nossles pop up on either side. Before I book into the stealers can any of you advice on anything I can check for myself? I didnt want to try and prise them out and in as I am an unsure if there is a manual release system in place shoud be auto mechanism get stuck for any reason. Thanks!
R32 : DBP : Lux Pack : Winter Pack : Cruise : Leather : Parking Sensors : Rear Tints : Armrest : RNS 510 : Ipod MediaIn : FreeView Tuner : VagCom
Offline finlayjacobin
  • JUST TOOK AN IQ TEST, THE RESULTS WERE NEGATIVE!
Re: Help - Xenon washers not working
« Reply #1 on: 02 September 2008, 18:38 »
Are you sure you have enough washer fluid?
In my old Lupo Gti which had xenons the washers did not work once the fluid went below a certain level, not sure if it the same in the Golf. HTH
56 MK5 GTI TORNADO RED, LEATHER, XENONS, 18 MONZAS, 6 CD ARMREST, EDITION 30 REAR LIGHTS, PAINTED LOWER FRONT AND REAR VALENCE AND R32 SIDE SKIRTS, AUTHENTIC PRESSED GERMAN PLATES, WOLFSBURG PLATE SURROUNDS, INPRO SMOKED MIRROR INDICATORS, CRUISE CONTROL THANKS TO VRSTU
Offline synnea
« Reply #2 on: 02 September 2008, 18:41 »
Washer fluid is full to the brim im afraid  :sad:
« Reply #3 on: 02 September 2008, 18:46 »
my technical opinion then is that they are buggered then!
or maybe it is just a fuse :smiley:
Offline SteveP
« Reply #4 on: 02 September 2008, 18:47 »
I believe you are correct on the once in every five uses of the windscreen washers but only only when the headlights are on.
Offline Teutonic_Tamer
« Reply #5 on: 02 September 2008, 18:47 »
Scuse the thick questions - needs to be asked though, but are the Xenons the proper factory fit items?  And are you positive they are actually Xenons?  (Some peeps think that projector headlamps also mean Xenons, which is obviously not true.  :rolleyes:)
What about the delay setting?
Make sure your ignition is on, and the headlamp switch is set to dipped headlamps (rather than relying on the Auto headlamps setting) - now pull and hold for 10 seconds the screenwash lever - and see if they work with an extra long delay.
I feel like a homo
Offline 182_blue
« Reply #6 on: 02 September 2008, 18:55 »
As above, do you have the two panels on the front part just under the light like the picture below, and do your headlights look the same as those in the picture too
Offline synnea
« Reply #7 on: 02 September 2008, 19:02 »
They are proper xenons for sure - factory fit. See the pic below of my car:
I think they are technically 'buggered' as I have the same results even when the lights are on. I could get them to pop up easy on my R32 after the 5 sprays on the windscreen. Would happen every time without fail.
Offline 182_blue
« Reply #8 on: 02 September 2008, 19:11 »
yeh there them, looks like a trip to the dealers, may be worth checking the fuses first ?
Offline Saint Steve
« Reply #9 on: 02 September 2008, 19:21 »
synea, just a daft question, but turn on your lights and try having a squert, and see if they work then. They only operate in the dark, lights are on, or breaking the speed limit if they are set on auto!.  :smiley:
just seen TT mention aswell  :rolleyes:
