Author Topic: induction kit or standard airbox with K&N filter?  (Read 1388 times)
Offline Drewcole
  • DaZeD aNd CoNfUsEd......
« on: 02 September 2008, 09:47 »
Hello,
When I bought my GTi 8v it had a pipercross induction kit fitted to it. I changed it back to a standard airbox and filter.
I kind of miss the noise a little but have noticed a difference in the drive of the car after removing the induction kit.
Just wondered what people run on theres and there thoughts on what is best?
Thanks.
jamie16v
Re: induction kit or standard airbox with K&N filter?
« Reply #1 on: 02 September 2008, 09:49 »
i think modify standard airbox with panel filter..
or an enclosed induction kit with direct cold air feed..
Offline Horney
« Reply #2 on: 02 September 2008, 09:56 »
Drilled and smoothed airbox with a decent panel filter is the best combo.
Nick
Offline Drewcole
« Reply #3 on: 02 September 2008, 10:00 »
Okay cool,
What do you mean by smoothed airbox? I drilled my last one and had a cold air feed directly into the bottom of it on my caddy.
and I assume that a you mean some kind of heat cover around the cone filter when you say enclosed on the induction kit?
Offline Horney
« Reply #4 on: 02 September 2008, 10:18 »
Smoothed = just use a file and some sand paper to remove any ridges or obstructions to clean airflow.
Enclosed is what you describe. Look up the BMC induction kits, they're the daddy!
Nick
Offline Drewcole
« Reply #5 on: 02 September 2008, 10:21 »
Nick
Great thanks Nick.
Offline bored_Welsh_lad
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
