Author Topic: HELP PLEASE  (Read 3397 times)
Offline sidecarphil
Re: HELP PLEASE
« Reply #20 on: 03 September 2008, 18:32 »
nope no cat or lamda
but the car is a 1989 car so over ere it should have had a cat fitted but it has been taken off i assume
Re: HELP PLEASE
« Reply #21 on: 03 September 2008, 18:38 »
ah so you are not in england then?
Offline sidecarphil
Re: HELP PLEASE
« Reply #22 on: 03 September 2008, 18:41 »
no mate netherland's LOL sorry but i am english :) Expat :wink: :wink:
Re: HELP PLEASE
« Reply #23 on: 03 September 2008, 18:54 »
aha!  I wouldnt have thought a lambda retrofit ecu would be significantly different to a 'normal' one, but it seems it is the case, unless there is something else wrong ;)
according to etka the ecu with part number 037 906 022BB can be replaced by:
037 906 022CT
037 997 022FX
there are probably more that will work made before the BB code ecu but I can only look forwards, not back!
Offline sidecarphil
Re: HELP PLEASE
« Reply #24 on: 03 September 2008, 19:02 »
thank you very much :)
i found a 037 906 022 CT on fleabay :)
dont suppose you have one ??
cheeRS phil
Offline danny_p
Re: HELP PLEASE
« Reply #25 on: 03 September 2008, 19:32 »
the digifant 2 ecu with lambda is very simalar to the non lambda one,   TC's  digi2 ecu runs lambda
all the VW's have gone bar 1.
Re: HELP PLEASE
« Reply #26 on: 03 September 2008, 19:54 »
yeah thats what I thought, etka has different numbers but assumed it was just a bit milder map for lambda or something.  obv the ecu plugs are the same!  plus when vw retrofitting a lambda dont want to be rippin out half car loom...
Offline danny_p
Re: HELP PLEASE
« Reply #27 on: 03 September 2008, 22:25 »
just thought in theory i have diagrams somewhere.
appently there are 4 maps stored on digi 2 ecu's  so all the ecu's have the same maps but depending which ecu it is depends on whitch map it reads
Offline danny_p
Re: HELP PLEASE
« Reply #28 on: 03 September 2008, 22:46 »
lambda ecu
pin 25 - ignition output signal to control unit
pin 18 - ignition signal input from dizzy
pin 2   - lambda
Offline sidecarphil
Re: HELP PLEASE
« Reply #29 on: 04 September 2008, 18:00 »
so can i just swap the pin's around on the wires ??
