Author Topic: Polishing up the inlet manifold  (Read 1909 times)
Offline Burnsy
« on: 09 May 2004, 19:59 »
Anyone tried polishing up there inlet manifold on there VR6 ?
If so how did you get on with it and what process did you use ?
Any pics
TiA
Offline warwickvr6
Re:Polishing up the inlet manifold
« Reply #1 on: 12 May 2004, 18:54 »
heres one I did earlier.
http://img2.photobucket.com/albums/v11/macuser/P4030009.jpg
http://img2.photobucket.com/albums/v11/macuser/eb643e98.jpg
http://img2.photobucket.com/albums/v11/macuser/ggg.jpg
First you have to take the manifold off but in my case I was doing the head gasket so it had to come off anyway.
You use the roughest sanding paper you can get (I used 600 grade) and take all the rough casting 'dimples' away so theres no low spots. you have to use your hands as you have to follow the contours of the mani. dont bother with the 'inbetween' areas as it looks good with the contrast in textures - also I left the sides rough. I used an electric sander but dust went everywhere (not sure about the health aspects of breathing this in so think about that if you have one !) There were really low spots so I had to really go to town on those bits.
When its smooth you can use finer paper and really work at it till its smooth. It may take hours and your hands will start bleeding. I did mine in stages - a few hours a day but I did the top part as well which was really rough and harder than the 'curvy' bits.
Use 1200 grade emery paper eventually (not sure if there is 1500 but that would be better) and sand it wet to get it smooth as possible. It will look pretty good at this stage; a sort of brushed aluminium effort but the best bit is when you polish it with crome or metal polish - it suddenly goes all shiny. You will still see lots of little scratches in it though; no problem just rub it gently with finest emery cloth again with water then polish again. You will eventually get a mirror finish but it takes along time and lots of effort - this can be done poorly or well depending on effort put in.
 :P :P
« Last Edit: 12 May 2004, 19:05 by warwickvr6 »
Offline Burnsy
« Reply #2 on: 13 May 2004, 19:23 »
Thnx for the reply m8 :)
Ive started working on it and ill post some pics when i feel there good enough to post
Great pics m8 hope mine turn out the same
« Last Edit: 13 May 2004, 19:26 by Burnsy »
Offline warwickvr6
« Reply #3 on: 14 May 2004, 13:25 »
thanks
good luck with yours.
