Author Topic: gerbox problem help needed  (Read 844 times)
Offline deedub28
« on: 31 August 2008, 15:44 »
hello all, i wondered if anyone has any suggestions as to how to remove the bolts holding the gearbox in place? they are multipoint socket type heads which have rounded off. i have tried the usual mole grips and lockable pliers to grip with no joy. i have also tried hex keys knocked in to turn still with no joy. i am unable to go any further with this until i can drop the old gearbox out. any help would be greatly appreciated. its a mk3 2.0 8 valve kind regards  the newbie
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
Re: gerbox problem help needed
« Reply #1 on: 31 August 2008, 18:40 »
Try an old 12-sided socket & a hammer if you can get it in there...  :evil:
Keeping schtum. Mostly.
Offline dai-cymru
  • 1989 MK2 16V
« Reply #2 on: 31 August 2008, 19:05 »
go for the equivelent 12 sided socket in imperial as there usually slightly smaller, or next size down and beat the socket on, or just grind the heads off and remove the rest later on when box is removed,
