Golf mk3
hardmonkeys
Headgasket issue!! possible mayo in my water??
Topic: Headgasket issue!! possible mayo in my water?? (Read 1112 times)
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
30 August 2008, 18:05 »
Well i gave the car a check today and under the water cap there was what looks like head gasket failure mayo (all though there was only a little!) and the water looks unclean/mirky .. It pressurises fine and the car runs perfect and it dosent seem to use oil (well its never being topped up in 10000 miles! and its just a little below where i filled it to
Is this a sign a something serious or shall i just give the coolant a flush and refill? and is it worth pressure testing (like you do when water is in the oil?)
Please help save my car as this could be terminal for her!!
kells
Guest
Re: Headgasket issue!! possible mayo in my water??
30 August 2008, 18:56 »
just sounds like condensation to me, do u hardly use it/do short trips only??
just done full coolant swap on mine and fitted new coolant bottle so i can actually see the levels now haha
davero
30 August 2008, 19:28 »
Agree with Kells, sounds like condesation. Probably due an oil change as well.
boneybradley
Forum Supporter
Back in a Mk3...
30 August 2008, 19:31 »
Condensation?? I only thought that would affect the oil......not the water?? i am gonna flush all the coolant out and give it some fresh and see how it goes...... what harm can it do!!
davero
30 August 2008, 19:36 »
Could be just bacteria/sludge, do the flush. If it was head gasket i think you would have mayo under oil cap as well.
kells
Guest
30 August 2008, 19:38 »
mine was murky as hell, now super clear pink (G12 PLUS) coolant
i had all bits in mine too, wouldnt worry too much, jus do a coolant swap and see how she blows
filthy
Here all the time
Reply #6 on:
04 September 2008, 21:29 »
If it runs fine, uses no water, doesn't overheat and no white smoke, then its fine...at worst it's probably the oil cooler, but if it was, you'd expect a fair amount of mayo, I wouldn't worry too much...
Having trouble keeping it on the straight and narrow?
www.powersteeringstore.co.uk
Golf mk3
hardmonkeys
