Author Topic: Anti roll bar...  (Read 975 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Anti roll bar...
« on: 30 August 2008, 00:46 »
Is it ok to run a 16v gti with no ARB?  I have converted my 1.4 to GTI suspenssion etc.. which means changing the wishbones.  sadly this means my ARB is diffrent.   as far as i can see the whole subframe needs to be dropped down to get to the ARB which is really not good as i desperatly need to get the engine in as my hoist broke so i have one on rental.   If its a big no no i will have to swap them over..   is it a big job?   It would fail mot if i left it disconected wouldnt it?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline boneybradley
  • Back in a Mk3...
Re: Anti roll bar...
« Reply #1 on: 30 August 2008, 09:39 »
You know how the mk3 suffers from body roll all ready!! Imagine losing the thing thats designed to reduce this.....and more so with the heavier engine and box fitted...
I would swap the wishbones over and fit the larger 22mm roll bars unless you like sea sickness!!
Offline Rmachines
« Reply #2 on: 30 August 2008, 11:15 »
I have swaped it to gti wishbones so its just the ARB i need to change.  but looks like a hell of a job to do without a ramp.
  • Back in a Mk3...
« Reply #3 on: 30 August 2008, 11:27 »
I believe it shouldnt be that bad?? then again Ive only ever changed the bushes...and they were fairly simple
Offline Rmachines
« Reply #4 on: 30 August 2008, 11:29 »
i can see how the bar comes off, that looks quite easy.  but as far as i can see the whole sub frame needs to be dropped down to remove the whole bar.
  • Back in a Mk3...
« Reply #5 on: 30 August 2008, 11:33 »
take off the link bars and the bushes and you should be able to slide the bar out? I beleive it will be a tight fit but should possible to do!!
Offline bobbito
  • Hammer and Chisel Engineering
« Reply #6 on: 30 August 2008, 16:34 »
You can get the arb out through the back of the subframe, undo drop links and pry the to retaining plates apart enough to slide arb through. I fitted H&R arbs which are alot thicker and still managed it didn't have to lower or slacken bolts on subframe. Best to get a mate to help as its fiddly as hell. If you need other info give me a shout. But you need an arb (even if its a stock one).
Offline Rmachines
« Reply #7 on: 30 August 2008, 16:56 »
I have left it off for now and will tackle this one on a ramp!   my 1.8 doesnt have one at all and that isnt any worse than my 1.4 with one. ?  Im not going to go without though!
