Author Topic: Fitting Hottuning coilies  (Read 1597 times)
Offline TATS
« on: 29 August 2008, 20:41 »
Hi, am about to have my Hottuning coilies fitted to replace the original shagged suspension on my 89 gti.
Can anyone give me a list of what i'll need, ie which top mounts to go for etc.
Never done this before so will take all the help i can get, many thanks
TATS
STOP IT, YER'LL GO BLIND TO YERSELF
Offline Mr Blue
Re: Fitting Hottuning coilies
« Reply #1 on: 29 August 2008, 23:01 »
Hi Tats
basic spanner set and a heavy hammer. You may also need that special tool to undo the topmounts (you will need the special bolt off your old set)
I just get the same matching GTi topmounts. Mine are NON genuine topmounts but have been fine so far.
Think thats about it :undecided:
Offline MarkS
« Reply #2 on: 29 August 2008, 23:11 »
Can I give a shout for g60 top mounts?
I believe they should fit hottuning coilovers?
Got a set on my Koni Adjustables
All good in the hood so far :afro:
And they're meant to be a bit stiffer than the GTi ones I think!
Offline Khare
  • The bear that khares
« Reply #3 on: 29 August 2008, 23:41 »
VR6 top mounts are the stiffest available i believe. Stiffer than the G60's.
Offline bigman_10
« Reply #4 on: 30 August 2008, 00:20 »
yeah the vr6 maye a little stiffer but they are slightly differnt in design and g60s are exactly the same looking as the standard so it would be staight forward for a novice. I paid £60 for my front two g60s. you'll need either an impact driver or air tool to get the nuts off though as doing it by hand can take the beeswax try and borrow one if you can.
oh yeah and and if they squeak when you have fitted then get some wd-40 between the two springs and the centre spring plate. for somereason that was the cause of an anoying squeak on mine?
Offline Khare
« Reply #5 on: 30 August 2008, 12:05 »
yeah mine swqueak too, i replaced both rear mounts and it stopped some squeaking but still there. i'l try the wd 40 in between both plates.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #6 on: 30 August 2008, 18:20 »
http://www.golfgtiforum.co.uk/index.php?topic=88303.0
This might help im going to put these on in a couple of weeks (The guide is for the mk3 but vertually the same). ive got a list of bits you need some where as ive just bought them from vw. Ive got the mk3 vr6 top mounts off ebay the links on the above link.
Offline TATS
« Reply #7 on: 30 August 2008, 19:39 »
That list would be a great help dude
TATS
« Reply #8 on: 31 August 2008, 08:35 »
http://www.aufg48.dsl.pipex.com/mk3strut.jpg
OK Ive just bought 2 of each of 23, 24, 28 came to about £16. This is with the mk3 vr6 top mounts if you go for the g60 ones i think you need some aditional bits.  :smiley:
« Reply #9 on: 01 September 2008, 10:15 »
problem with using MK3 GTI/VR6 mounts is you need a specific top spring mount for them to work properly, so if the coilover kit is designed for a MK2 they may not fit.
