Golf mk3
hardmonkeys
Power boost valve?
Topic: Power boost valve? (Read 1249 times)
bobbito
GTI forum regular
Hammer and Chisel Engineering
Power boost valve?
28 August 2008, 22:37 »
Are power boost valve worth the £89.99?
Usually i'd stay away from anything with the words, power and boost in the same sentence as its sounds like something you add to a childs remote toy but the add on FSE power boost valves sounds slightly attractive. Would it be a good idea on a 2.0 8V gti.
01664gti
mk3 hatch mk3 wagon and mk2 16v
Re: Power boost valve?
28 August 2008, 22:41 »
Hi i am selling one on ebay now,Its on a gti im breaking. The power gain is not that noticable to be honest, but it may make throttle response better. and to be honest anything that make an 8v quicker is a good thing lol
Last Edit: 28 August 2008, 22:47 by 01664gti
boneybradley
Forum Supporter
Serious forum addict
Back in a Mk3...
28 August 2008, 22:42 »
waste of time......
your car will control fuel by various engine sensors and anything the boost valve does will be quickly over ridden by the ecu making any gains un-noticable!
kells
Guest
28 August 2008, 23:22 »
the only people that buy them are people with alot more money than sense
davero
28 August 2008, 23:29 »
I put one on my 16v for about 2 hours, then it went promptly back on ebay, waste of money.
01664gti
28 August 2008, 23:48 »
Thats why mines on ebay lol
bored_Welsh_lad
Reply #6 on:
28 August 2008, 23:52 »
Only good if you have the extra mods to go with it... it just raises the fuel pressure... friend of mine had one on his punto gt, but that was because it was pushing out over 200 brake
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come
Bumper Vents
bobbito
GTI forum regular
Reply #7 on:
29 August 2008, 11:13 »
Cheers for the rapid response guys. I was looking at 01664GTI's on ebay but thought i'd gets some professional realistic advice from you lot. Saved me a few quid....beers on me.
Thanks again.
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Reply #8 on:
29 August 2008, 21:47 »
They are handy things if you have big mods. a good way of getting the pressure up safely but usless on its own. throttle responce would be slightly higher but as said before the engine compensates as much as it can to keep it running how its supposed to. So dont bother.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Golf mk3
hardmonkeys
Power boost valve?
