Author Topic: ABS lights on ????  (Read 1905 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
ABS lights on ????
« on: 28 August 2008, 14:04 »
Hi all my abs lights come on for the first time,Any ideas what it could be??.
I just wondered if it was a common problem
Offline boneybradley
  • Back in a Mk3...
Re: ABS lights on ????
« Reply #1 on: 28 August 2008, 14:14 »
common fault and its most proberbly this http://www.golfgtiforum.co.uk/index.php?topic=57396.0
all though mine has come on and gone off a few times due to a seized handbrake cable!!
Offline Mikester
  • Civic Type R
« Reply #2 on: 28 August 2008, 15:10 »
Ive replaced all but 1 sensor on my gti. And guess what!
My abs lights back on!!! lol
  • Back in a Mk3...
« Reply #3 on: 28 August 2008, 15:19 »
Did you do a scan for fault codes??
Offline Tom H
  • Previously board-stupid! :D
« Reply #4 on: 28 August 2008, 15:26 »
Mines on too while we're on the subject, BUT mine also occasionally makes a werid grinding noise - best way I can describe it is that the first time It happened I thought a platic bottle or something had caught under the front of my car. After the noise the light goes of for about 10 minutes or so, then comes back on again - any ideas on that one? I wondered if the caliper might be fuct?
Offline 01664gti
« Reply #5 on: 28 August 2008, 15:29 »
How do i scan for fault codes?? and how many sensors are there??
« Last Edit: 28 August 2008, 15:31 by 01664gti »
  • Back in a Mk3...
« Reply #6 on: 28 August 2008, 15:34 »
Sticky caliper or a knackered handbrake cable (if its on the back?).....mine has done this in the past and a quick freeing of the caliper and cable sorted it.......
and you can get a fault code reader connected up to your car and this will scan the abs ecu for any faults stored...or see if someone on here can connect you to vag-com
Offline Mikester
  • Civic Type R
« Reply #7 on: 28 August 2008, 15:35 »
One sensor on each wheel, they measure the wheel so then it knows when you are skidding and can kick in.
If the sensor is faulty, the ECU brings up the light and turns of the abs.
Offline 01664gti
« Reply #8 on: 28 August 2008, 15:39 »
LOL oh great i better buy 4 then lol,
what is vag.com??
Offline Baskey
« Reply #9 on: 28 August 2008, 17:33 »
F*ck me theres some quality information on this site.
Although my girlfiends mk3 is pritty mint it has a couple of niggly probs, this being one (ABS light). Im going to check all the sensor's as described in the guide but the handbreak does seem a little rough so im wondering if its a little seized. If it is will it be the actual rear calipers (iv just had to re-build the rear calipers on my clio 172  :angry:), or the routing of the cable thats the common problem?
