Author Topic: Exhaust repair putty stuff... any good?  (Read 2666 times)
Offline tim145tim
  • 1997 GOLF GTi 16v ANNIVERSARY Mystic Blue Pearl
« on: 28 August 2008, 10:48 »
Hi guys, my exhaust is blowing ever so slightly on the back box...
its not in the main body, its just along one of the seems of the box... a slight crack...
As I dont want to replace it for a month or 2, I was going to use some exhaust repair putty on it...
anyone used this? does it, will it work?
how long for? any advice? thanks
Offline Mikester
  • Civic Type R
Re: Exhaust repair putty stuff... any good?
« Reply #1 on: 28 August 2008, 10:51 »
Used it on my motorcross bike. worked fine for me :D
Offline Horney
« Reply #2 on: 28 August 2008, 11:00 »
Yeah I've used the HAlfords own brand repair paste and it does the job fine. Once you've put it on let the car idel for a bit to warm the exhuast then turn it off and leave it over night. Job's a gooden!
Nick
Offline bored_Welsh_lad
« Reply #3 on: 28 August 2008, 11:07 »
I av to do this all the time, as i clonk my cat on the drive all the time..
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline Mikester
  • Civic Type R
« Reply #4 on: 28 August 2008, 11:10 »
Thats so dubbin.....SPORTS cat ftw
Offline MrTurner
  • Facelift leon cupra
« Reply #5 on: 28 August 2008, 14:37 »
Whenever I've used it, I've found it to be sh!t!  For the amount of effort and money to repair it, I'd be tempted to wait for it to get bad, then replace than mess about.  I'm sure there must be a cheap standard back box kicking about on here/fleabay?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #6 on: 28 August 2008, 16:38 »
Its more for fitting to joints than trying to patch holes.  we always use it on exhaust joints and it does a great job.  Not really made for patching holes in backboxes.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 28 August 2008, 16:41 »
Weld it.......as thats your best bet and some exhaust places do it for a couple of quid (mine does and most of my midlle box and middle pipe has had work!!)
Offline tim145tim
« Reply #8 on: 28 August 2008, 16:42 »
Theres two kinds...
One is for assembly,
One is for permenant repair.
O well I'll just try and see if it works, it only costs £3, and the cracks small
Offline MrTurner
« Reply #9 on: 28 August 2008, 16:50 »
That's what it says on the packet  :grin:
