Author Topic: What would the symptoms be....  (Read 991 times)
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« on: 27 August 2008, 21:55 »
of a warped disc on the rear drivers side be..?
Reason i ask is i have this noise that only happens when i brake and is definatly coming from the caliper area, it slows as the car does, sounds like something on the wheel that is hitting the ground each time it goes round but its deffo from the caliper area as ive run beside the car as the missus was driving slowly and listened as she braked.
Any sure way of finding out..?
Offline saul79
Re: What would the symptoms be....
« Reply #1 on: 27 August 2008, 21:57 »
jack it up and spin it round
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline davero
« Reply #2 on: 27 August 2008, 22:39 »
Had a bit of gravel lodged in my brake pad, it gave those symptoms.
Offline oliver07
  • golf gti T 200BHP
« Reply #3 on: 30 August 2008, 07:15 »
check between the disc and the metal backing plate as this was a problem i had once the stone pops out good as new  :grin:
Offline filthy
« Reply #4 on: 04 September 2008, 21:31 »
could even be a loose wheel bearing?
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline DazVR6
« Reply #5 on: 05 September 2008, 12:38 »
Can better decribe it as a creaking from the caliper area that stop starts and slows as the car does.
Offline beccasmk3gti
  • golf mk3 gti and a mk3 vr6 182bhp and 223nm
« Reply #6 on: 06 September 2008, 07:53 »
had same problem on my nova sr it was caliper moving on mounting bolts when u breaked could see it move when u breaked on it.
