Author Topic: coil pack is doing my headin!!!!!  (Read 1030 times)
Offline lawson_gti
« on: 27 August 2008, 20:38 »
i put a new distrubuter on 2weeks ago as the other seemed to stiff and got a brand new 1 from the scrappy for 15quid so i thought thats it im havin it as most placeses sell them 2nd had for 55quid!! gd job i found the car!! now my coil pack has gone bang!!! got a new 1 and 2day this 1 went so took it back an they replaced it an this 1 is f**ked!!! can some1 plz tell me wat the volts should b going into the coil as my mate said it could b some resister for the volts!! its for a mk3 golf 2l gti!!!
some1 help lol
Offline Saffa
Re: coil pack is doing my headin!!!!!
« Reply #1 on: 27 August 2008, 22:16 »
Hi,
You should have 3 wires upto the coil, an ignition live ( battery voltage - 12-14volts max ), the signal wire (centre) and a earth. Good way too check is to check battery voltage using a voltmeter across terminals, then check ignition live wire too coil between wire and battery earth terminal, this should match the battery voltage roughly, then put voltmeter between ignition live feed wire to coil and earth wire from coil and compare voltages, they should all be roughly the same and not above 14 volts. It may also be worth checking voltage across battery terminals with engine running, this will check if your alternator is not overcharging, the maximum voltage when running should be 14-14.5 volts maximum. normally it is around 13.5 - 14 volts.
Hope this helps.
Jochen.
Offline lawson_gti
« Reply #2 on: 27 August 2008, 23:46 »
yeah i cheacked them and it said 12.2 on both battery and the live wire on the coil, i have a volt meter in my piller pod an that says wen its jus engine running with no lights on the neddle is on the 14 but just a bit over but with lights on jus under 14 lol i was told by a mate there should be some sort of resisiter cant remember wat its called an that should stop over valtage for example if it only needed 6valts it would stop it from sending 14, is there anyeasy way of finding out were this resister is??otherwise it looks lik ill b emptying my wallet to vw 2 fix problem lol
cheers jochen for the advice!!!!
« Last Edit: 27 August 2008, 23:49 by lawson_gti »
Offline Saffa
« Reply #3 on: 28 August 2008, 21:54 »
Hi again,
The coil should run at 12-14 volts, there is no resistor that I know of, and I have worked on VW since 1989 hahaha.....
May be it is worth checking your distributor cap and rotor arm condition? and king lead, as maybe they are bad and causing too much drain on the coil pack? either that or your just getting a batch of duff coils? what manufacturer are they from? is the earth strap ok that bolts too one of the securing bolts?
Jochen.
Offline lawson_gti
« Reply #4 on: 28 August 2008, 22:05 »
it had new dizzy cap 1month ago and looks ok and rotory arm 2weeks ago as my car seems to eat threw them lol err leads are bout 6months old an look clean!! even the gold connectors do, they are from bromsgrove motor factors in worcester think the box said automotive not sure its a yellow an blue box. well took it into garage to get looked at as i nearly started to make my nice shinny car look lik a rat lol (got a short temper with electrics lol) ill let u no wat the garage says lol plus its only wen im driving it cuts out as was sat at idle for bout 15mins this morn an it never missed or f**ked up once lol
Offline Saffa
« Reply #5 on: 29 August 2008, 21:45 »
Hi,
Are you sure its the coil thats giving the problem? the speed sender ( common prob ) can cause it to cut out and also the fuel pump and e.c.u power relays are also known problem area's.
Hope the garage can get it sorted for you.
Jochen.
