Author Topic: Filling up problem  (Read 2332 times)
Offline AlanD
  • MK5 2.0T 16v
Filling up problem
« on: 27 August 2008, 18:12 »
This has happened several times now, at first I thought it was just something wrong with the petrol pump but its happened about 5 times now and different stations. I will go fill up and it will only let me stick about £1-£2 of petrol and then clicks as if I have reached the limit. Today I was in desperate need of petrol as I had to drive back home (London) from Oxford, had to fill up £20 worth £1 a time which was not good.
Anyone had this problem before or know what the possible cause could be?
Offline bacillus
Re: Filling up problem
« Reply #1 on: 27 August 2008, 18:48 »
That has happened to me in the past at certain petrol stations!
To overcome it I rotate the pump nossle clockwise and that usually stops the pump clicking off.
Without traction power is nothing!
Offline Top Cat
« Reply #2 on: 27 August 2008, 18:55 »
I think it's your angle of dangle  :laugh: i just pull it out a bit or push it in more to suit when this happens.
Also if premature ejaculation petrolisation continues think of margeret thatcher this should help.  :smug:
Offline Makaveli
« Reply #3 on: 27 August 2008, 19:35 »
Never had this in the GTI but had it a few times in the S3 - did the same as above ie. rotate the nozzle and it seems to sort it  :smiley:
Offline T88OMM
« Reply #4 on: 27 August 2008, 20:00 »
I get this all the time!!! I think there must be something inside the filling hole on the GTI that stops you being able fill it up easily!!  :angry:
Tom
Candy White ED30 | Carbonio | Turbo-Back Milltek | Autotech Fuel Pump | Stage 2 Custom-Code Remap
Offline bacillus
« Reply #5 on: 27 August 2008, 20:50 »
It's probably a fail safe mechanism to stop you putting in anything but V power...   :grin:
Offline SteveP
« Reply #6 on: 27 August 2008, 20:54 »
Mine has no problems gulping down Tesco's finest, drinks it like a fish  :grin:
Offline AlanD
  • MK5 2.0T 16v
« Reply #7 on: 27 August 2008, 21:56 »
Well, im glad this isnt just me then. Next time this happens I shall try said advice. Cheers guys.
Offline gazbutmk5gti
« Reply #8 on: 27 August 2008, 23:00 »
T88OMM where have you beeeeen!!!!!!!
Revo stg2+ & lots more
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 28 August 2008, 09:17 »
just put the straight part of the nozzle through the flap, if you shove the cranked part down the tube it senses back pressure as the fuel splashes off the filler neck and cuts the feed
