Author Topic: Cant get into gear....  (Read 738 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 26 August 2008, 19:36 »
Was fine but the clutch bite was very low and it crunched into gears, now its not going into gears at all!  Its hydraulic clutch i know that much.  Basicly the clutch needs to be adjusted so its further up the peddle.
What could cause this?  As its hydro clutch i presume its not adjustable at all so its going to be either bludging pipes or in need of a fluid change/bleed?
I have checked the box out and the linkages and its all fine.  engages perfect with the engine off so deffo a clutch issuse.  Wink
Any ideas? cheers.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Stu G
Re: Cant get into gear....
« Reply #1 on: 26 August 2008, 19:49 »
if its hydraulic clutch see if its seperate to the braking resovoir. if it is try bleeding it. there will be a bleed nipple on the slave cylinder attached to the gearbox. if this dont work its cabbaged
