Author Topic: need HELP rough running mk1 cab any ideas what i can try?  (Read 2147 times)
Offline mrgreendog
if anyone can help me my cab is running so rough it's embarassing sounds like it's missing badly it's a H reg 1.8 gti, i've checked the obvious stuff like plugs leads & dizzie they're all fine, dunno if might be a fuel problem? only just had it mot'd & it was fine it just developed this fault.. any ideas to try will be welcomed before i have to send it to a garage which no doubt will cost sh!t loads.. matt 07971081576
Offline [han]
  • Graphic Designer for Haribo
Re: need HELP rough running mk1 cab any ideas what i can try?
« Reply #1 on: 27 August 2008, 13:53 »
is it all the time?
from cold or only when hot? does it stop when up to temp?
Offline gibby
« Reply #2 on: 27 August 2008, 14:46 »
Do a search in this section as there are a number of similar threads with various things to try.
Has it got a rusty filler neck ?
......now officially dubless.
Offline mrgreendog
« Reply #3 on: 27 August 2008, 15:37 »
it did have but i changed the tank N neck for a second hand one could it be rust getting sucked up then making it run so badly? i'll take the sender out n get a magnet in there see what comes out.. thanks for the reply
Offline mrgreendog
« Reply #4 on: 27 August 2008, 15:39 »
is it all the time?
yeah it's all the time it did clear for a bit & was running good but has now started playing up again!! thanks for the reply
Offline gibby
« Reply #5 on: 27 August 2008, 17:39 »
Aye, could have sucked up some of the rust from the filler neck and tank.
