Author Topic: Front Discs / Pads  (Read 2736 times)
Offline GOLF_MK
Front Discs / Pads
« on: 26 August 2008, 16:12 »
I have to replace my Front Discs and pads asap as the discs are shot.
I have measured the discs and they are the larger (288mm ones)
I don't want to spend a fortune as i have lots of other things to do to the car but don't want to get rubbish that will warp the first time i brake hard either  :grin:
I've heard that Brembo Max from GSF are good but what pads to go with them?  Any other i should look at?
Thanks  :smiley:
Offline boneybradley
  • Back in a Mk3...
Re: Front Discs / Pads
« Reply #1 on: 26 August 2008, 16:15 »
eurocarparts do ate power discs which are good quality and lightly uprated... matched with ate pads you should have a decent set up thats not o.t.t.
Offline bored_Welsh_lad
« Reply #2 on: 26 August 2008, 20:21 »
Ive got brembo discs with greenstuff and they are a bit noisy until they get up to temp but then they are awesome.
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline GOLF_MK
« Reply #3 on: 26 August 2008, 21:09 »
Thanks guys, think i'll get a price for dealer ones and go from there.....
« Reply #4 on: 27 August 2008, 08:23 »
wtf.... i wouldnt bother wih stealer... gsf/gmf/ecp but not the stealer
Bumper Vents :D
Offline GOLF_MK
« Reply #5 on: 27 August 2008, 10:43 »
After getting a price I won't be  getting them from a dealer, sometimes genuine parts prices are a surprise but i'm sure i can get cheaper / just as good elsewhere;
Discs £40.60 + vat each
Pads £52.27 + vat
£156.83 in total....
Offline Guy
« Reply #6 on: 27 August 2008, 11:23 »
Pads £52.27 + vat
GSF - it'll be all you need
http://www.gsfcarparts.com/contact/map.asp?location=IP15BN
Offline Mikester
  • Civic Type R
« Reply #7 on: 27 August 2008, 11:51 »
I have the same... I can stop very quick without needing to push the pedal that hard, or use abs... Which makes the passengers suprised when you brake just that bit harder! :laugh:
Offline beccasmk3gti
  • golf mk3 gti and a mk3 vr6 182bhp and 223nm
« Reply #8 on: 27 August 2008, 20:02 »
Thanks  :smiley:
ive got brembro max grooved and there well good and pritty cheap
ive got the pagid bads with them like some one else said bit noisey until warm but then spot on. thats on my vr6
« Reply #9 on: 27 August 2008, 21:13 »
no my greenstuff pads are noisy not ur pagid.. i said it first  :drool:
Bumper Vents :D
