Author Topic: MY Gti Sound like a 3 Potter, What s going on?  (Read 1962 times)
Offline dubin
  • If it ant rubbing, it ant Dubing.
« on: 26 August 2008, 14:30 »
As above.
I started the Engine the other day, let it tick over and with out any warning it just sounded sh!t. Almost as if it was running on 3 cylinders.
I was showing of the Car to a friend in the street, and i tough i'd start the engine "As You Do".
Any was, one second it was running fine, the next CRAP.
I did'T touch the accelerator at all during the time it was running, as i never do until i see a reading on my MFA "Oil Temp"
Now i thought it might be "Fuel" as the gauge was reading Empty, So this morning when i got in from work i when to the garage put a 10er in and when i started the car it still sounded the same.
so this after noon, i started the car and removed one HT lead at a time to see if it could be a Spark plug.
I started from the CAM side of the engine and worked my way to the Gear Box. HT lead 1 removed stared up worse, HT lead 2 removed No real change but if i touch the accelerator wounded rev good "missy", HT lead 3 removed "Same result as HT Lead 2 and HT lead 4 same result as HT lead 1.
So now i'm thinking it could be, that the timing may have slipped a tooth.
Dose any know were i can find some thing on the timing for my GTi "1.8 16v" or has this happned to you before and know what it is.
Jez.
1988 mk2 Golf GTi 1.8 16v
LA5Y - Helios blue metalic
It takes 800 bolts to make a car. It take one nut to take it a part.
Offline davidhawkins_78
  • Valver Bad Boy
Re: MY Gti Sound like a 3 Potter, What s going on?
« Reply #1 on: 26 August 2008, 14:34 »
Hall Sender I'd start with . . . and check the cam sensor plug on the dizzy first!
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline DubFan
« Reply #2 on: 26 August 2008, 14:57 »
What's with all the "speech marks" ?
Offline dubin
« Reply #3 on: 26 August 2008, 15:36 »
Would't the engine not fier up if it was the Hall sender. I checked the plug it looks ok.
Just been on the phone to VW and for a new distridutor its going to cost me 103 pound.
Be for i go out and buy one, has any one got any more thought as to why the engine is runing rough as FCUK.
« Last Edit: 26 August 2008, 15:43 by dubin »
Jez.
Offline Conker
« Reply #4 on: 26 August 2008, 18:07 »
Don't buy anything until you've diagnosed the problem, although £103 for a genuine VW dizzy is good value.
In terms of checking ignition timing:  http://www.golfgtiforum.co.uk/index.php?topic=56707.0
In terms of checking static tooth timing, have a search of the dedicated Mk2 section (http://www.golfgtiforum.co.uk/index.php?board=7.0), but preferably buy a Haynes as the timing is fully detailed in there.
The car can still start with a dodgy Hall Sender. A good symptom of hall sender issues is your rev counter jumping around. Oil can leak into the dizzy from the head and affect the sender, so a good spray of WD40 helps clean it out.
A good (but dangerous) way to check your plugs and leads is to remove a lead and plug and then get a mate to turn the engine over with a spark plug earthed on the rocker cover (don't electrocute yourself!!). You can then visibly see the quality of the spark and check for arcing etc.
Also have a look at buying a new dizzy cap and rotor arm which only cost a few quid - much less than the whole dizy!!
My bet would be on dodgy HT leads.
Offline dubin
« Reply #5 on: 27 August 2008, 16:16 »
turns out is was the Spark Plugs, but found that out once i when and bought the dizzy cap and arm first.
I changed the dizzy arm and it just sounded even worse so put the old one back on, i bid't even bother trying the dizzy cap so when back down to my local parts shop and got some NGK plugs, but i'l change then for a set of BOSH super 4s at a latter date.
She back to full health agen  :grin: :grin:
Thank for the help guys, hope i can return the favor some time.  :smiley:
Jez.
Offline Conker
« Reply #6 on: 27 August 2008, 21:06 »
Leave the new arm and cap on anyway you stingy bugger!
 :grin:
Offline dubin
« Reply #7 on: 29 August 2008, 06:31 »
 :grin:
I'l put them back on some time to day, but when i put the rottor arm on the other day it sounded crap.
Jez.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #8 on: 29 August 2008, 23:45 »
Compression test time?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
