Author Topic: Error - airmass sensor wiring (520)  (Read 762 times)
Rob Needham
« on: 26 August 2008, 11:20 »
had the old vag-com on her last night! error 520 popped up (airmass sensor wiring b),
anyone ever had the same issue? basically the car wont rev past 5000rpm.
Offline bored_Welsh_lad
Re: Error - airmass sensor wiring (520)
« Reply #1 on: 27 August 2008, 09:48 »
Same old...
timing could be out a tooth
fuel relay could have gone
ecu relay could have gone
crank position sensor may have gone
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline saul79
« Reply #2 on: 27 August 2008, 18:48 »
what engine you got in it? Sometimes the wiring to the sensor rubs through
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline lawson_gti
« Reply #3 on: 27 August 2008, 23:58 »
i have this problem as well!!! 2weeks ago it wouldnt pull an lik lost power after 4k revs now its pulling all the way 2 5k revs lik a dreams then lik dies!!! i no my sensor if f**ked as car runs pretty much the same with the sensor off!!! but took it apart an cleaned the terminals with a coton woll bud an sorta helped the idle an smoothness of the engine running but hasnt fixed the problem!!!
