Author Topic: please please help, over fueling heap  (Read 1056 times)
Offline homerhobson
« on: 25 August 2008, 18:58 »
Hello, several months ago i worked out that the reason my car had been running rough was the air flow meter was broken and secondly the Lambda sensor was 1. broken to 2. noy connected. I purchased a new sensor and due to the previous owner of the car taking a chain saw to the wiring had to re solder the wires on the harness. I nice man with an autodata set up gave me all the releveant coulourd wires just to make sure i was connecting the right wires back to the right wires ( if you catch my drift. ) Today on the way back from town the car started playing up and i only just made it back coupled to this it was only doing 10 mpg where it had been doing 27 mpg. I thought ah that old chest nut the lambda sensor has gone again. I plug in my code scanner a sure enough it came back with lambda sensor. I checked the joints id soldered and re did a few of them becasue i didnt know if it was a dry joint etc. Ran the car again ( after reseting the fault codes ) and the car runs like a bag of S&*TE but when i plug the code reader in it dosnt through up the lambda sensor code. Is it possible that the wiring is now ok but the sensor is not returning the correct voltage to the ECU so the code reader is not picking up the fault code because there is no broken wires etc. Also with out spending a vasrt amount of money on manuals where can i get an electrinic wiring diagram so i can check out a few things on this car.
Any help would be most appreciated.
Thanks
Ben Hobson
email -  bhoson15@googlemail.com
Offline danny_p
Re: please please help, over fueling heap
« Reply #1 on: 25 August 2008, 22:25 »
to give you any sort of help / advise would need to know what  model age and engine
all the VW's have gone bar 1.
Offline homerhobson
« Reply #2 on: 26 August 2008, 09:48 »
Hello there, engin is very early VR6, car is a 93 K reg, engine AAA,   code scaning wire has only 2x connectors. Going down garage now to have a look underneath the car to see if any wires are broken.
What else do you need to know.
Thanks
Ben
Offline danny_p
« Reply #3 on: 26 August 2008, 19:14 »
that should be enuff for someone to help, i don't do much with vr6's myself.   would suggest looking at the airflow meter tho  possobly the throttel body (  throttel position sensor in particular )
