Author Topic: which wheel spacer kit to go for ?  (Read 2005 times)
Offline boneybradley
  • Back in a Mk3...
Re: which wheel spacer kit to go for ?
« Reply #1 on: 25 August 2008, 16:32 »
heres mine (in sig picture) with 15-16mm rear spacers and it does sometimes rub a little!! and thats with narrow 195's! when i had 205's fitted I couldnt carry anyone in the back for long!!
« Last Edit: 26 August 2008, 09:05 by boneybradley »
Offline RiCHiE360
« Reply #2 on: 25 August 2008, 16:34 »
I would personally buy them from here..
http://www.venommotorsport.com/product_details.php?id=334&manufacturer=FK&category=Wheel
Their branded and you know what your gettin, also wouldnt go as far as 20mm if your runnin 205/50 tyres mate
Roofless VR6 FTW
Offline remapped
  • If you are going through Hell, keep going
« Reply #3 on: 25 August 2008, 16:38 »
cheers for fast reply dude
looks like time for new rubber as well !! it will be 195s  :cool: for sure
will tease 15mm ones be ok ?
http://cgi.ebay.co.uk/VW-HUBCENTRIC-WHEEL-SPACER-KIT-15mm-GOLF-BORA-AUDI-SEAT_W0QQitemZ220272758911QQcmdZViewItem?hash=item220272758911&_trkparms=72%3A984%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Also i should ONLY get hub centric ?
like the way you one is sitting brad
« Last Edit: 25 August 2008, 16:41 by remapped »
OEM(ish) G3GTi 8v5dr
Offline remapped
« Reply #4 on: 25 August 2008, 16:40 »
cheers link noted !
Offline bored_Welsh_lad
« Reply #5 on: 25 August 2008, 17:00 »
yeah i would certainly only get hubcentric ones mate..
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline green-blood
« Reply #6 on: 26 August 2008, 09:03 »
On the same topic - fronts, has anyone spaced out their fronts.
I'm on early mk3 gti alloys and I wanna keep them and the cr has been lowered on a H+R kit (40mm) so the rears need to get spaced but I'd like to move out the fronts a bit too
  • Back in a Mk3...
« Reply #7 on: 26 August 2008, 09:07 »
my fronts are 3mm (all though not hub centric and with standard bolts!! :shocked:) but with them being so slim there barely noticable to the untrained eye... I do want some proper 10mm ones tho
Offline green-blood
« Reply #8 on: 26 August 2008, 09:22 »
Was thinking 5/8 mm, but I dont want to introduce any rubbing... thanks for eth feedback.
With your 15/16 mm rears, is it rubbing on the arch lip, perhaps some amateur rolling might help!!
  • Back in a Mk3...
« Reply #9 on: 26 August 2008, 09:45 »
yeah I'm sure with a little massaging of the lip they will be fine??
