Author Topic: How hard is it to change timing belt on MK3 16V?  (Read 1142 times)
Offline richieboy
« on: 25 August 2008, 12:52 »
Hi, i am wanting to change the timing belt on my 1996 16V ABF and i was just wondering how hard it is?  I was quoted £270 from the stealership and £260 from an independent VW specialist :shocked: so i thought i would do it myself. I guess i will change the tensioner and belt as this seems like the done thing to reduce problems down the line. I noticed that GSF do tools for the tensioner but there are two codes which are 98777 and 98778, does anyone have an idea which one i need? Also if anyone has a guide how to change the belt that would be much appreciated.
Thanks in advance
« Last Edit: 25 August 2008, 15:52 by richieboy »
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: How hard is it to change timing belt on MK3 16V?
« Reply #1 on: 25 August 2008, 17:32 »
you dont need the specialist tools, just remember how tight your old one was.  better to have them to loose than to tight.
Its a nice easy belt to do. Same as the 8V.  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline 95gtipete
« Reply #2 on: 25 August 2008, 21:42 »
Its not that difficult. Just make sure you got a strong breaker bar and you put the tensioner on correct or the plastic cover will not fit back on. if the timing is slightly out just adjust the distributor.
