Author Topic: Top mounts, shocks.....Help!!  (Read 1626 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 24 August 2008, 15:17 »
Just fitted an ABS sensor (yep, another one!) and whilst I had the wheel off I checked my discs which have a nice lip around them.....being the 288mm means  :cry:
Anyway.... I can move the shocks (both of them) up by hand by about half an inch, this is by lifting the disc, the top mount as in pic goes up and down, is this normal??
Pics of each top mount whilst car is level.......
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Top mounts, shocks.....Help!!
« Reply #1 on: 24 August 2008, 15:26 »
Ummm,  that gap apears when you lower the car so yea thats normal.  Dont think the shock should be loose though?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #2 on: 24 August 2008, 15:41 »
She does'nt have lowering springs just standard springs and shocks...... unless they have been cut at some point?
From the pics of the top mounts does it look like she has been lowered?
Offline Mikester
  • Civic Type R
« Reply #3 on: 24 August 2008, 15:43 »
He means, when you lower it, as put it on the ground, not jacked up. Not as in SLAM it
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 24 August 2008, 18:42 »
top mount looks fine... but im not 100% what you mean about the shockers?? but im guessing you mean the top mount moves with the strut? and this is normal as at normal height they sit like in the photos and will have about and inch of up/down movement for when a wheel drops into a pot hole etc
Offline Mikester
  • Civic Type R
« Reply #5 on: 24 August 2008, 18:51 »
mine aint that high tbh, i just looked when i checked oil n stuff. They are raised but not that high, and mine were all replaced this week.
  • Back in a Mk3...
« Reply #6 on: 24 August 2008, 18:59 »
mike as you said "yours were new this week" older ones will be more flexible and strechy
Offline Mikester
  • Civic Type R
« Reply #7 on: 24 August 2008, 19:00 »
I seee  :embarassed:
Offline AudiA8Quattro
« Reply #8 on: 24 August 2008, 20:37 »
That gap looks too big to me, i would say they are quite knackered.
Offline 95gtipete
« Reply #9 on: 25 August 2008, 21:44 »
Same gap as mine. I know mine are shot!
