Author Topic: golf mk 2 gti 8v battery draining problem  (Read 1306 times)
Offline robgti8v
« on: 24 August 2008, 14:24 »
hi all new to site i have a golfgti mk2 8v recently i changed the stereo and since then the battery kept draining have taken stero back out but still have problem can any one help p;lease
rob
Offline Uruk Hai
Re: golf mk 2 gti 8v battery draining problem
« Reply #1 on: 24 August 2008, 16:09 »
Check as much of the wiring as you can or pull the fuse of one thing at a time overnight and see what its like the next day ?
Offline raferackstraw
« Reply #2 on: 24 August 2008, 19:55 »
disconnect neg lead from battery and connect a multi meter between the terminal and the disconnected lead, set multimeter to read amps
you should see an amp reading above normal [anything above 1amp is wrong]
then remove each fuse one by one until you see the amps return to below 1 amp
this will pinpoint the circuit that is causing the drain
i did the same when i fitted a stereo and found i did not have a switched live
your problem sounds the same in that you have the memory live, connected to the switched and memory on the stereo
also check charging by putting a multimeter across teminals with engine idling you should get about 14v
check battery is holding a charge
« Last Edit: 24 August 2008, 20:01 by raferackstraw »
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline robgti8v
« Reply #3 on: 25 August 2008, 12:38 »
thanks for help will try it out and will let you know if it works
rob
« Reply #4 on: 26 August 2008, 12:37 »
check the boot and glovebox lights arnt stuck on :)
Offline MarkS
« Reply #5 on: 26 August 2008, 14:05 »
That old blighter got me before!  :grin:
