Author Topic: shakey jake!!  (Read 1043 times)
Offline Benny T
shakey jake!!
« on: 24 August 2008, 09:42 »
When ever i pull away my car shakes! You know when you don't have the clutch quite at the correct bighting point, but it's not that because it does it when i have the clutch pretty far in and out. It seems to be worse in reverse and kinda clunks a bit too.
I've got it pretty low on coilovers which i think could be part of it.... Could the clutch need adjusting?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: shakey jake!!
« Reply #1 on: 24 August 2008, 10:38 »
if you have clutch judder the only cure is a new clutch.   Could be worn or contaminated if its doing that.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline boneybradley
  • Back in a Mk3...
Re: shakey jake!!
« Reply #2 on: 24 August 2008, 12:18 »
I would also check the engine mounts as these a prone to failure.....I had one go on my old gti and it juddered as the engine was moving lots under acceleration
Offline Benny T
Re: shakey jake!!
« Reply #3 on: 25 August 2008, 20:24 »
ok cheers, will have a louk!
Offline bored_Welsh_lad
Re: shakey jake!!
« Reply #4 on: 27 August 2008, 08:28 »
If its the front mount thats gone, you can replace with 3 ice hockey pucks and it will be like running a vibramount on it.. awesome stuff at a minimal cost!
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
