Poll
Help needed......... Does anybody know the location of the "Output Stage For The Ignition Coils"?
ANY IDEA
2 (20%)
DO YOU KNOW
8 (80%)
Total Members Voted: 9
Author Topic: HELP PLEASE !!!!!!!!!!!!!!!!!!  (Read 1679 times)
Offline dickie_brown
« on: 23 August 2008, 20:32 »
HI
My car is a 1998 GOLF GTi TURBO 1.8 Mk4
AGU Engine.
The car has a missfire, we have proved all four (4) Ignition coils are fine, the plugs have been replaced also, but still there is no spark on cylinder 3.
We suspect a possible cabling fault, loose/broken wire etc (unless someone knows different) between the Output Stage For Ignition Coils(which we cant find) and the ignition coil and.
Each ignition coils has three cores connected to it, two of which are common to the other coils, we suspect these two are ok as all three other fires fire ok. The core we need to check is the Grey(Gr)/Black(Sw).....but we need to know where the Output thingy is located.....can anyone help!!!!![/b]
Offline Conker
Re: HELP PLEASE !!!!!!!!!!!!!!!!!!
« Reply #1 on: 23 August 2008, 22:10 »
I voted "Do You Know".
Hope that helps.
Offline Top Cat
« Reply #2 on: 23 August 2008, 22:33 »
i voted havn't any idea
Offline Mr Blue
« Reply #3 on: 23 August 2008, 22:46 »
How did you test the coil packs exactly?
The wires do break on these 1.8t's near the coil pack. ive had to solder these before and then heat shink etc...
Swap the suspected faulty ign coil (3) with coil number 4 and then do another fault code check. If it shows as a missfire on coil 4 now then you know what to do  :wink:
not much help but its a broken wire or faulty coil pack. doubt its anything else mate.
« Last Edit: 23 August 2008, 22:48 by Mr Blue »
Offline Conker
« Reply #4 on: 23 August 2008, 22:48 »
Blue, you wasn't supposed to say all that shizzle, just vote dude.
Dave
 :grin:
Offline Mr Blue
« Reply #5 on: 23 August 2008, 22:50 »
my bad  :grin: now voted ''do you know''
Offline richw911
« Reply #6 on: 23 August 2008, 22:53 »
See im not so sure i think its more "ANY IDEA" TBH........
:grin: :grin: :grin:
Offline Conker
« Reply #7 on: 23 August 2008, 22:59 »
I've just watched this and feel it might help with your coil pack probelm.
http://www.youtube.com/watch?v=NRIIGSvjrMw
It heped me pis myslef.
Offline richw911
« Reply #8 on: 23 August 2008, 23:19 »
Come over to the mk4 section dickie lots of help there  :wink:
Offline Conker
« Reply #9 on: 24 August 2008, 22:42 »
Blimey, I was a bit drunk last night then.
 :undecided:
