Author Topic: hi sorry cutting out questens  (Read 1020 times)
Offline ricky680
  • Limited
  • Scammer
« on: 23 August 2008, 15:31 »
right i just got an mk3 8v on an r reg its a tidy litte car worth the 450 i paied it has the cutting out prob whatss the first things i shold look at
If you have sent this person money for items not received, please claim back via paypal and let topher know when you have been refunded. DO NOT send this person any more money
http://www.golfgtiforum.co.uk/index.php?topic=108469.0 See this thread for details.
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
Re: hi sorry cutting out questens
« Reply #1 on: 23 August 2008, 22:15 »
Give the throttle body a good clean with carb cleaner    :smiley:
Keeping schtum. Mostly.
Offline 95gtipete
« Reply #2 on: 25 August 2008, 21:21 »
Defo the Throttle body. I had the same problem for months changing fuses and bloody sensors along with relays. Could not take the throttle body off so removed the pipe sprayed carb cleaner in and straight away the butterfly closed on its own accord. Hold the butterfly open while run a toothbrush around inside. Then put it back together. It may not want to start straight away but once it does you will have no problems again.
