Author Topic: Re-setting ECU to adapt to BP102  (Read 1732 times)
Offline djhorace
  • Yee ha!
« on: 22 August 2008, 22:33 »
I have VAGCOM, and I believe there are some things that can be reset in the ECU to adapt immediately. Can anyone confirm this, or would it be a case of just disconnecting the battery like on the old 1.8T's?
Bought 21 litres of BP102 today at £2.42 a litre to see if it actually is "all that", and would like to make the most of it so to speak.
Offline gazbutmk5gti
Re: Re-setting ECU to adapt to BP102
« Reply #1 on: 22 August 2008, 23:08 »
think its just a case of driving and letting the ecu adapt to it :smiley:
Revo stg2+ & lots more
Offline bacillus
« Reply #2 on: 22 August 2008, 23:12 »
can you not just increase the timing?
afaik your ecu will still need to adapt regardless of you resetting it.
some say turning on the ignition then flooring the accelerator pedal for 10-15 seconds till all the noises under the bonnet cease resets the ecu but haven't tried this myself.
Without traction power is nothing!
Offline vRStu
« Reply #3 on: 23 August 2008, 10:32 »
As far as I understand it you can 'force' a new adaption by clearing a fault code in Controller 01 Engine.
Stu
Offline bacillus
« Reply #4 on: 23 August 2008, 10:49 »
Stu will his car have a "fault" code if there is no problem with the engine controller?
Could you elaborate on what needs to be done?
Offline vRStu
« Reply #5 on: 23 August 2008, 11:13 »
You can introduce a fault code by unplugging the MAF and then turning the ignition on, no need to start the engine.
Stu
Offline bacillus
« Reply #6 on: 23 August 2008, 11:25 »
excellent info...
Offline RedRobin
« Reply #7 on: 23 August 2008, 14:14 »
....According to Revo, you can reset the DSG's learning with vagcom.
