Author Topic: Engine  (Read 1577 times)
Offline benjam_in
Engine
« on: 06 May 2004, 11:43 »
How loose is eveyones engine if i hold mine firmly i can move it but it does require a bit of force?  ::)
Golf Mk2 Gti 1988
Blue MK2
Re:Engine
« Reply #1 on: 06 May 2004, 12:07 »
probably due to an engine mount. mine could be moved but took abit of force..nakkerd front mount, so i changed it.
Does your car shake at idle?
Offline benjam_in
Re:Engine
« Reply #2 on: 06 May 2004, 12:28 »
Not massively!  ??? recon i could be a mount cos you can feel it move when u accelerate and my exhaust keeps coming loose!
Golf Mk2 Gti 1988
Offline Dizzie
  • Make friends with your fast
Re:Engine
« Reply #3 on: 06 May 2004, 13:47 »
I had an annoying 'banging/tapping' noise when the front mount was gone.
Offline Gambit
Re:Engine
« Reply #4 on: 06 May 2004, 13:58 »
lift the bonnet of your car, then sit in the car and start it
put the car in reverse and lift off the clutch a little - you will be to see any movement engine bay thru the gap at the bottom of the bonnet
do in first gear also
engine mounts are relativly cheap to buy & replace
