Author Topic: Please help... Im going nuts with wiring.  (Read 1359 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 22 August 2008, 10:04 »
Right, before i get angry and smash it up i think i had better ask.
First of all.  If i unplug everything from the back of the fuse box on a MK3 will i ever know what goes where again? or is each plug diffrent?
And HOW THE HELL DO THEY COME OUT????   I push the tab in on the plug and it lifts at one side, but the other side will NOT unplug from the fusee box, and there is no tab. usualy it just pulls but i really dont want to break it.
The whole loom is coming out of the car to go in another one.
Cheers.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Re: Please help... Im going nuts with wiring.
« Reply #1 on: 22 August 2008, 12:52 »
yeah each plug will only go into the correct socket, 2ndly you also have to release the locking bar that runs  down the middle of the fusebox between all the plugs.  Look at 1 end of the fb and you'll notice a tab thing, grab that and pull :)
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #2 on: 23 August 2008, 11:34 »
Remember the golden rule of wiring: Red to Red, Green to Green and Blue to bits  :grin:
Keeping schtum. Mostly.
Offline Rmachines
« Reply #3 on: 24 August 2008, 08:52 »
Quote
Remember the golden rule of wiring: Red to Red, Green to Green and Blue to bits  grin
PMSL!!! HAHAH  :grin:
Right im gunna crack on with it today! i will let you know how it goes.
Oh and another wiring question... How do i get it through the bulk head?   Does the plugs in the fuse box end all fit through the hole?   If so how do i get access to the hole?   Remove the brake servo?
Cheers.
« Reply #4 on: 24 August 2008, 12:19 »
on a mk2 yeah you have to pull the brake servo forward to get to the bungs, assume its same on a MK3.  I didnt have to unbolt any of the brake lines either, just very carefully pull it forward.
Offline Rmachines
« Reply #5 on: 24 August 2008, 12:38 »
I have got it all out of both cars now.   Not nearly as bad as i expected!  it looked really scary but its all plug and play so thats good.
Just goto get my head arround the peddle box etc.. now  :smiley:
