Author Topic: Wiring looms... ughh  (Read 885 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 21 August 2008, 18:08 »
Bloody nightmare!  Trying to pulll out all of the wiring looms for the 16v.  Getting it out is very tricky!  getting it in will be almost impossible i think  :grin:
Anyway..  Does the servo have to come out to get to where the loom enters the fusebox area?  And which way does it come out?   Do i have to unplug it from the fuse box and pull the plugs through the bulkhead or will it all fit through the other way,   if possible i would like to keep as much in the fuse box as possible.
I have to change all of the dash loom as well,  its a right pain!    And is there a trick to getting the damn plugs out of the back of the fuse box, doesnt seem to make any diffrence if i push the tab in and pull, they just will NOT release.   I dont wanna go and pull all of the wires out of the plug  :smiley:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline grimmer
  • www.check-light-on.co.uk
Re: Wiring looms... ughh
« Reply #1 on: 22 August 2008, 19:43 »
ive done this many times, it can be done with the servo on, just unbolt the master cylinder and move it a few inches to the side, feed a few connectors through at a time, then go into the car and pull them through, do this a few times and they all will come through, as for the back of the fusebox, are u sure u have fully pulled out the plastc bar what runs through the middle of the fusebox,
on my gti, i swapped my 8v to the 16v, i only needed to change the engine managment side of the fusebox, all the dash wires and loom stayed in.
i can change the whole loom on the engine to the fusebox from disconnecting the old and installing the new loom in under a hour, so its not to envolved really.
MK3 GOLF GTI 8V  now converted to 16v!!
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 24 August 2008, 12:48 »
if you are doig all the wiring use this site for diagrams http://volkswagen.msk.ru/index.php?p=page09_g3 should come in handy?
Offline Rmachines
« Reply #3 on: 24 August 2008, 15:10 »
cheers, i have swaped it over now,  wasnt nearly as bad as i expected in the end!  Got a few more bits to do then its ready for the engine to go in  :smiley:
