Author Topic: VW GTI Mk5 Warranty Recall  (Read 5539 times)
Offline DamoGTI
« on: 20 August 2008, 13:03 »
Hi,
Local dealer called me up 2 weeks ago and said they needed to do a recal. They swapped the ECU and fuel pressure sensor over.
Has anyone had this experience? Mines an 06 DSG.
Offline Cooper7
Re: VW GTI Mk5 Warranty Recall
« Reply #1 on: 20 August 2008, 13:08 »
Yea had mine done yesterday, also had the headlamp level sensor replaced under warranty after i asked them to have a look at the headlamp levels cause i couldn't see more than 10m in front of me at night!
MKV Steel Grey GTI
Offline neg
« Reply #2 on: 20 August 2008, 14:58 »
Fuel pump is a common thing on 06 models as for swapping the ECU - are you sure it wasnt just an update?
Offline Rollini
« Reply #3 on: 20 August 2008, 15:05 »
yeah i had the fuel pump one done on my service last week and had an ECU update a little before that - no replacement ecu though  :undecided:
Offline Cooper7
« Reply #4 on: 20 August 2008, 16:07 »
I had the fuel pressure sensor replaced and an ECU update
MKV Steel Grey GTI
Offline RedRobin
« Reply #5 on: 20 August 2008, 18:15 »
....Has anyone got the reference # for the fuel pressure sensor replacement issue - A good VW dealer will have entered it on your paperwork.
Also, the last ECU update was 24K6 or are you reporting a more recent one?
Offline neg
« Reply #6 on: 20 August 2008, 18:58 »
If he's just had the pump swapped I am guessing its the same update (24K6) - both relatively old to be honest.
I dont think they class the pump as a recall even, some dealer will only swap if you throw up the right code.
Offline RedRobin
« Reply #7 on: 20 August 2008, 20:27 »
....We discussed this fuel pressure sensor recall in some detail in another thread and IIRC it's not a big deal. My VW dealer mechanic explained why I didn't need the swap but I think I suffer from short term memory loss - I remember that it made sense at the time.
Offline mb
« Reply #8 on: 20 August 2008, 21:17 »
My invoice shows 'carried out 24m5 recall'
Offline RedRobin
« Reply #9 on: 20 August 2008, 21:31 »
....Great!! Exactly what I need to check with my VW guy again. Seeing him on Friday when I steal their new Scirocco for a bit.
Thanks mb :cool:
