Author Topic: Sluggish and lumpy  (Read 1931 times)
Offline Justins145bhpMK1
Sluggish and lumpy
« on: 05 May 2004, 11:19 »
Hell all, been a while since ive been on here.
My 2.0 8v has become increasingly sluggish and unresponsive of late.
Had a problem with oil getting up into the air pipe as some idiots at a garage had overfilled the oil. Cleaned al that out and it seemed to run better but has now got worse again. It fels like its stuttering through accelearation. Help??
Offline Overseer
Re:Sluggish and lumpy
« Reply #1 on: 05 May 2004, 11:50 »
clean throttle body... ?
« Reply #2 on: 05 May 2004, 16:54 »
Done that, any other ideas??
Offline Overseer
« Reply #3 on: 05 May 2004, 17:12 »
check that bit you cleaned before over again i supposed.. check for leaks too?
Offline N-Wales_vr6
« Reply #4 on: 05 May 2004, 20:00 »
What about the cat? it says you should'nt overfill the oil as it could fook the cat! :o Try some cat cleaner type stuff
