Author Topic: service reset problem  (Read 2954 times)
Offline nadlad
  • Building Surveyor MRICS
« on: 17 August 2008, 00:44 »
my golf was originally on the long life with the standard clocks it now has bora sport fis display does anyone know how to reset the service interval i have tried to do the golf procedure but ti does not work
that was
ignition on hold a together then it says @service now@ when i turn the other knob it does nothing
any ideas thanks
<<<Big Build Thread>>>
Offline Rhyso
Re: service reset problem
« Reply #1 on: 17 August 2008, 08:44 »
Offline GTi-Matt
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline nadlad
« Reply #3 on: 17 August 2008, 12:50 »
when i turn it to the right it still says 'service now'????????????
Offline T_J_G
« Reply #4 on: 17 August 2008, 13:00 »
from what i remember there's two ways of doing it. Try searching for a semi recent thread that explained it. although it may have been wiped when the forum went down.
Offline Rhyso
« Reply #5 on: 17 August 2008, 14:07 »
try this way
With ignition switched off press and hold the trip reset button.  Switch ignition on and release the reset button.   Turn the knob to reset the minutes on the clock to the right and the display should return to normal.
Offline nadlad
« Reply #6 on: 17 August 2008, 14:35 »
rhyso...
i tried that method but i was expecting a confirmation message or somethign once i turn the knob after about 5 secs it goes to normla display.
Offline Rhyso
« Reply #7 on: 17 August 2008, 17:41 »
rhyso...
you won't get a confirmation message
when you turn the ignition does it come up with service now? if not then its reset
Offline nadlad
« Reply #8 on: 17 August 2008, 21:10 »
no i had my clocks changed with about 1400 miles to go till service  so i knew it was due around 67k so just wanted to sync the new clocks in if u know what i mean...
Offline Rhyso
« Reply #9 on: 17 August 2008, 21:14 »
you've confused me......
your old clocks had 1400 until the service then you put in new clocks - i would have thought thats set to 10,000 miles....
you can use VAG COM to reset it again if you really want too i guess
