Author Topic: Vacuum pipes question  (Read 1936 times)
Offline Diluxe
Re: Vacuum pipes question
« Reply #10 on: 31 August 2008, 10:06 »
well i cleaned out the ISV & bought another WUR of ebay
attempted to start the car and it was so lumpy I thought the engine was going to come off its mounts, adjusted the mixture screw clockwise the revs picked up & it idles beautifully.
any idea why i needed to adjust the idle mixture after changing/cleaning those two items?
if i turn the idle screw clockwise am i enriching the mixture?
1997 16V
« Reply #11 on: 31 August 2008, 10:11 »
yeah clockwise raises the co mixture, either the old wur was making the car run too rich, or the new isv is allowing more air through it?
Offline Diluxe
« Reply #12 on: 31 August 2008, 22:25 »
i may swap back to the old wur and see if i have turn the mixture back down, what i did notice is the car doesnt feel as lively now, theres a bit of raod near me & i struggled to hit the same top speed over the same distance, so somehow I seem to have lost the enrichment top end or the advance, I seemed to have cured one problem but created another ...........................
1997 16V
Offline Diluxe
« Reply #13 on: 01 September 2008, 21:11 »
can anyone recommend a garage in the Berkshire area that will fuel pressure/flow test?
1997 16V
« Reply #14 on: 01 September 2008, 21:30 »
theres storm whihc isnt so far, and the phirm is very good but it can take a while before they can fit you in!
Offline mattkh
« Reply #15 on: 01 September 2008, 21:51 »
Hi
You are keen ! How many new washers will you have to use to reconnect the fuel pipes to the WUR ?
Have a look at the back of the old WUR and see if you can see the hole having been drilled to alter the fuel pressure.
Offline Diluxe
« Reply #16 on: 01 September 2008, 22:33 »
Hi
what there where washers on the fuel lines  :shocked: :grin:
yeah checked that as soon as i got the old one off, to see if the WUR mod had been done it hadnt, I was going to put the old wur back on too see if i still had the original problem, I noticed something else today, i can hear a whistling noise from the replacement WUR sounds like its coming from the air hole on the front face of the wur , the one with the plastic cap on, is this supposed to make a noise?
1997 16V
