Author Topic: sound deadening  (Read 4131 times)
Offline Kingt_mk2
  • you could call it complex simplicity?!
sound deadening
« on: 13 August 2008, 20:11 »
sorry if this is in the wrong section, please move if so
anyone know of a cheap, and very effective way os sound deadening?? as soon to be putting in a new interior and thought it would b a gd idea to put some dynamat (or wotever its called) in but its very exspensive!! any ideas??
:: 1988 Golf 1.8 16V ::
Offline Conker
Re: sound deadening
« Reply #1 on: 16 August 2008, 21:11 »
Staple egg boxes EVERYWHERE.
 :laugh:
Offline Uruk Hai
Re: sound deadening
« Reply #2 on: 17 August 2008, 09:57 »
Offline Kingt_mk2
Re: sound deadening
« Reply #3 on: 21 August 2008, 09:39 »
 :laugh:
haha  :P at least it will b quite comfortable when i crash i spose
Offline malco
Re: sound deadening
« Reply #4 on: 22 August 2008, 13:35 »
You could do worse than something like this :-   http://www.wickes.co.uk/Aluminium-Flashing/Hi-Tack-Flashing-Strip/invt/243010
My mate fully lined his Vito out with that and it's made an incredible difference, waaaaaaaaaay cheaper than dyna mat too and almost the same effect.
Gonna do my Golf as I go along/next take bits off.
1998 - Mk3 GTI 8v - Dragon Green
Offline Kingt_mk2
Re: sound deadening
« Reply #5 on: 24 August 2008, 10:24 »
are you sure? roofing felt to b used as sound deading material??
Offline malco
Re: sound deadening
« Reply #6 on: 25 August 2008, 10:36 »
Noooo not roofing felt, flashing tape, totally different stuff. It's almost the same as Dynamat but for about a quarter of the cost. We've tried both branded Dynamat and standard flashing tape and there was no real difference between them in the end result. Flashing tape is heavier though.
Offline bored_Welsh_lad
Re: sound deadening
« Reply #7 on: 27 August 2008, 07:57 »
I was just going to say the same thing. im thinking of trying it around mine just to remove some of the reverbaration(sp) from the pipe
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
