Author Topic: Uprated Fuel Pump opinions/ideas on 200PS GTI  (Read 7294 times)
Offline k4ith
Re: Uprated Fuel Pump opinions/ideas on 200PS GTI
« Reply #20 on: 22 August 2008, 20:03 »
R/R I am curious as to why someone at VW, tech or not would advise to stay away from uprated fuelpumps what do they base this suggestion on?
As for myself the day is almost upon me(mon) Autotech fuelpump and R32 front brakes being fitted.
....Btw, you know that Monday is a Bank Holiday?
I heard it second hand but am up there on Tuesday so I'll ask first hand. Would it help you if you PM'd me your mobile and I phoned you sometime on Tuesday? But I don't know what time it would be.
Yes parts of Scotland are closed on monday but for most its not a holiday.So by Tues it will have been done lol.I was just curious as i know you have friends in motorsport/tuning.
I meant to say in previous post that for some reason Eibach ARB's seem to squeak on the MK5 golf& mk2 leons for some reason i had this on my leon and have heard of another golf having the same issue.
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline djhorace
  • Yee ha!
« Reply #21 on: 22 August 2008, 22:29 »
To be honest, the wear issue can be addressed, and the higher volume of fuel could cause a bit of an issue with regard to displacing oil. There is a fair chance a lot of people who have bought a brand new Golf GTi are not going to keep their car for a duration longer than say 3 years so therefore within the warranty period. What happens after that is not going to be a problem to the first owner.
R/R - you should really say whats on your mind rather than make a statement and not back it up with fact. If you have information about issues an uprated pump can give, surely it would do us all a favour by letting us know exactly what the issues may be.
[/£0.02]
Offline RedRobin
« Reply #22 on: 22 August 2008, 23:00 »
[/£0.02]
....Sorry but until I have info which I can be confident is reliable, it would be potentially very misleading. I was at this stage, until I can find out more info, merely flagging that issues exist and hoping to do this community a service by making people aware. Anyway, I am not THE one and only expert on this site - I'm just networking and sharing info for the benefit of all, including myself. I am very conscious of 'expert opinions' varying and sometimes even conflicting and I am always anxious not to post wrong or misleading info, even unintentionally.
Regarding the Fuel Pump, my current understanding is that there were serious issues with the first aftermarket ones manufactured but this has been solved. Also I now understand that fuel pump issues have been only on particular engine series but I don't know which at the moment - Perhaps someone else here does.
I hope to share more info in due course and hope you now understand 'where I'm coming from'.
This is already probably common knowledge but the FP is very tightly controlled by the ECU because fuelling in the FSI engine is very critical. However, the behaviour and interactions between FP and ECU are, I believe, smart. I stand to be corrected but that's my understanding.
All any of us can do is to post information which is to the best of our knowledge at the time.
Offline RedRobin
« Reply #23 on: 22 August 2008, 23:03 »
....I had the same issue after about 40,000 miles - It was the poly bushes on the ARB's needing regreasing/lubing.
Offline Top Cat
« Reply #24 on: 22 August 2008, 23:09 »
sorry to interupt the flux capaciter thread but Red Robin were is the scirocco write up  :rolleyes:
Offline RedRobin
« Reply #25 on: 22 August 2008, 23:15 »
....25 pics ready and I just took a quick break to catch up here. I am midst writing and will now go back to it. I hope to complete it tonight but it could be a long night!
Offline Top Cat
« Reply #26 on: 22 August 2008, 23:19 »
Sod ya then, im going to have to sit with the mrs now  :wink:
Offline RedRobin
« Reply #27 on: 23 August 2008, 21:58 »
....Something I forgot to post : - If you have an aftermarket fuel pump it's recommended to check it and the 'cam follower(?)' about every 5,000 miles, I'm told.
Offline vRStu
« Reply #28 on: 23 August 2008, 22:03 »
5k might be a little frequent IMHO.  I did mine at about 7-8k and it was fine.
Stu
Offline RedRobin
« Reply #29 on: 23 August 2008, 22:43 »
....I'm not saying something would need fixing but only a suggestion of 5k as a yardstick. The advice I got was to check regularly. So I guess you'll check again in another 7-8k. I find it easier to work in intervals of 5/10/20k.
