Author Topic: Squicky break noise  (Read 3303 times)
Offline maksinx
Squicky break noise
« on: 12 August 2008, 23:12 »
hey guys,
I bought a  mk4 which makes irritating noise when pressing break pedal,
it is a squickly noise which happens on dry weather mainy,
do you know why it happens and also how i can avoid?
thanks in advance.
Offline richw911
Re: Squicky break noise
« Reply #1 on: 12 August 2008, 23:25 »
Almost all brake squeal in disc brakes comes from brake pad vibration against the caliper.
 To stop this the friction clips and the areas of the pad that make contact with the caliper need to be thoroughly cleaned and degreased with brake parts cleaner and lubricated with dielectric grease, caliper lube, or anti seize compound. (Any of them will work)
Offline Ben_1uk
« Reply #2 on: 14 August 2008, 15:36 »
I don't know if this would be covered by any of the above but copper grease also works a treat!
Powered by the fuel of satan!
Offline richw911
« Reply #3 on: 14 August 2008, 19:40 »
indeed anti seize compound/ copper grease  :smiley:
Offline Dubbz
« Reply #4 on: 15 August 2008, 19:28 »
I got Pagid on the front, they squeel like a b!tch when breaking softly  :angry:
took them out today, slapped more copper grease on and scraped the pads on the ground to take the shine off..  :shocked:
hopefuly sorted for a while, i reckon they'll need doing again in a couple of k's  :rolleyes:
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #5 on: 20 August 2008, 22:53 »
wot he said :smiley:
